is it possible to do it?
atm im doing it like this, converting the .ogg to .avi then trying to put it onto dvd. its successful apart from the subtitles
https://www.videohelp.com/forum/viewtopic.php?t=241422
i followed that, but in the end i dont kno how to get it onto dvd with subtitles because i dont know what to do with the video.srt
Results 1 to 16 of 16
:D
thank you guys for your help, if i have any more problems ill just post here
:D -
sorry to bother u guys again, the files i need make onto dvd are .ogg files, not .ogm.
these are my steps so far...
1) Convert .ogg to .avi using https://www.videohelp.com/forum/viewtopic.php?t=241422
2) By using this i get 2 files that need to be with each other to work, video.avi and video.srt
3) This is where i get stuck, i dont kno how to make the 2 into one file. If it is in one file, then i can get it onto Dvd. But when its in 2 files, i cant get it onto dvd with subtitles ><:D -
iv just checked again and the files are .ogg and do not say anything about .ogm :X. Are there no programs to get .ogg onto dvd?
:D -
When ogm first went public people were even using .avi as an extension. Naming an ogm an avi doesn't make it an avi just as naming an ogm .ogg doesn't make it a true ogg file. If you can open it with VDubMod then it is an ogm file.
For converting ogg theora files you could load via dshow using Radlight or illuminable's filters or use mplayer or ffmpeg. mplayer/ffmpeg would need to be compiled with theora, vorbis, etc. enabled.
Not sure if it is possible to extract theora from an ogg to avi. But you should at least be able to extract the audio. -
well i can open the so called .ogg file, with virual dub, thats what i have been using to convert it to .avi BUT it gives it to me in 2 files (.avi and .srt - subtitles) and i dont know how to put them onto dvd with subtitles
:D -
i posted the link to the guide i was using, i followed that and got 2 files that somehow need each other to play like the original file
:D -
Well, then question change a bit:
Have you read any guides HOW TO PUT AVI WITH EXTERNAL SUBTITLES ONTO DVD at all?
DVD Workshop 2: Where is the best tutorial for this project?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2010, 10:09 -
HD-DVD conversion tutorial
By heretic619 in forum Blu-ray RippingReplies: 11Last Post: 27th Feb 2010, 22:48 -
DVD to AVI tutorial?
By darkdream4 in forum DVD RippingReplies: 3Last Post: 6th Jan 2010, 02:19 -
video tutorial dvd-lab pro
By waefwaeefwaefw in forum Authoring (DVD)Replies: 1Last Post: 27th Oct 2008, 11:53 -
Tutorial: Using DVD Shrink to extract ONLY THE MOVIE
By RogerTango in forum User guidesReplies: 3Last Post: 11th Dec 2007, 22:35
hehe woops
I have posted already
