When I try to convert to DivX on the virtualdub and look at the preveiw the pictures look the same, and it says projected file size like 58 gig or 5.8 gig, either way, how can I get it to work for converting to DivX?
Hi
If you are loading a uncompressed avi, both windows will look the same. the right window will only change when you might select a filter.
When you save you need to select Video > Compression, then select a DivX codec. Now when you Save AVI it will save the avi compressed using the codec you selected.
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 13:42 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 19:23 -
VirtualDub Mod Conversion from DVD, no audio in FCE
By Jralph in forum Video ConversionReplies: 2Last Post: 29th Apr 2009, 10:09 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 22:13 -
VirtualDub conversion
By Flying Doctor in forum Video ConversionReplies: 9Last Post: 6th Nov 2007, 04:45
