I have been working on creating an image slide show with "Slide show Movie Maker" all weekend. Goal is to build still image shows with music that will play on a DVD player. I like this show because of its very nice transitions. Here's what I am doing:
1. put jpegs and audio wav file in SSMM.
2. Use the codecs SSMM suggests: XVID MPEG-4
and PCM at 16 bit 44/100 KHZ stereo for audio
3. convert to DVD with DIVX to DVD
4. Burn the resulting video-TS with Nero burning ROM 6.6 version.
The audio plays the first 10 seconds, stops and then back to first 10 seconds over and over. I think it has got to be an audio codec problem. The one I am using is the only one SSMM will accept. Maybe I should go hunting for another audio codec?
Thanks for any help on this.
Carolro
Results 1 to 1 of 1
Audio skips
By tendo.kagwa@gmail.com in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2011, 11:26 -
Mpeg 2 for Blu-ray audio exports with missing frames at beginning and end.
By jbandy1 in forum EditingReplies: 0Last Post: 21st Jan 2009, 16:34 -
Any way to insert 1 frame image at the beginning of an mp4 (using AutoGK)
By cryptyk in forum DVD RippingReplies: 11Last Post: 10th Sep 2008, 22:03 -
Image PPI -> DVD slideshow...does it matter?
By Grunberg in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2007, 17:06 -
Using Avisynth Transition PlugIn For AVI Still Image Slideshow
By wiseant in forum Video ConversionReplies: 4Last Post: 24th Oct 2007, 12:45
