? Comcast Digital Cable Recording ?
My question seems simple but after searching the web I am left in a confused state. Although the setup I’m looking for could be used in multiple ways I am only interested in one particular function right now. I want to be able to record music vidz off my Comcast digital cable and transfer those files to my PC where I can then convert the vidz into smaller files so I can fit many vidz on a DVD which will then go into my car and ultimately be playing on my headrest LCD screens.
My original thought was to go with a stand alone Pioneer DVD recorder with an 80gig hard drive. This way I could record the vidz while I was gone at work. When I got home I would pick the ones I wanted to keep and burn them to DVD. Then I would take the DVD to my computer and copy them down. This thought was shattered once I found out that the DVD recorder did not have a tuner that would reach over channel 125. Most of my recordings will be above the channel 125 range. I do not have an HD box, just a Comcast digital cable box.
My second thoughts was to build a PC and record the vidz to the hard drive then transfer the files over Ethernet to my ‘Master’ PC to do all the editing but once again I can’t find a tuner card that would take the signal. I was unsure on how I would separate the videos, would it look like just one big 2 hour recording or can you actually split the vidz up later?
Anyway, I just want a setup that works whether it be a stand alone machine or simply adding a card to my current machine. Money isn’t really of any concern so please don’t feel like you have to suggest a system that is cheap. Don’t get me wrong I don’t want to spend thousands of dollars but I am willing to spend more than a few hundred for this functionality. I do not care about pausing live TV nor do I care about fast forwarding through commercials.
My current bedroom setup:
TV:
42” Toshiba Widescreen HDTV
2 RF tuner inputs (only one used currently)
2 Component inputs
2 S-Video inputs + 1 in front
2 Composite (RCA) inputs +1 in front
1 DVD Player over Component
1 VCR player (no longer hooked up)
1 Comcast digital cable box (black) over coaxial
PC:
Asus IC-7 Motherboard
Intel P4, 2.1c Ghz, oc’d
1 gig Geil Dual DDR PC3700 RAM
2 Raptor 36gig 10K SATA drives setup as RAID 0
1 Maxtor 200 gig 10K SATA drive for storage
ATI Radeon 9800 256mb video card running dual LCD display setup
10/100baseT LAN and 54G Wireless card (currently wired to the Linksys router)
Sound Blaster Live (old I know BUT great for audio capturing)
Logitech DiNovo Bluetooth Keyboard & Mouse
Windows XP, SP2
HELP PLEASE![]()
Cable Box -> S-Video + audio ->
1 DVD recorder with HDD (pick songs and burn DVDR)
2 Capture card in computer
3 Pass-Thru DV Camcorder to IEEE-1394 input on computer.
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 21:27 -
Integrating Dishnetwork with Comcast Cable
By ramsium in forum Media Center PC / MediaCentersReplies: 1Last Post: 6th Oct 2010, 07:04 -
dvr recording with Comcast Digital
By rdbierma in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 15:47 -
Help hooking up Panasonic DVD recorder to Comcast cable HD DVR
By KeithJFro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 22nd Feb 2010, 17:17 -
By KeithJFro in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2010, 15:20
