When I try to run the SVCD2DVD v1.5 program I get this error message
When I try to run the sVCD2DVD v2 I get this error message:Code:Variable uses an Automation type not supported in Visual Basic at CodeLock._Secure.Initialize(String protected_file) at AxCodeLock.AxSecure.Initialize(String protected_file) at _S_VCD2DVDMPG.2f5590cb48bb0c53.83f20715bdcc4873(Object e0292b9ed559da7d, EventArgs fbf34718e704c6bc
Code:Version:SVCD2DVD 2.0 RC9b Type: System.NotSupportedException Source: CodeLock Message: Variable uses an Automation type not supported in Visual Basic InnerException: StackTrace: at CodeLock._Secure.Initialize(String protected_file) at AxCodeLock.AxSecure.Initialize(String protected_file) at x3284ccece41ee22b.x2f5590cb48bb0c53.x83f20715bdcc4873(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.SetVisibleCore(Boolean value) at System.Windows.Forms.Control.set_Visible(Boolean value) at System.Windows.Forms.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322395(String[] xce8d8c7e3c2c2426)
How can I make this shit go away so I can use the program??
Results 1 to 16 of 16
What is your Operating System?
Operating System: (WinXP Professional 5.1 Service Pack 2 (Build #2600)) ¤ Uptime: (3d 31m 29s) ¤ Record: (1w 3d 8h 24m 6s set on Sat Mar 19 11:37:24 2005)
Memory Usage: (Usage: 669/1023MB (65.40%) ¤ (||||||||||||||||||||----------)) ¤ Display Info: (1024x768 16bit) ¤ Monitor: (Plug and Play Monitor)
CPU Info: (1 CPU - Intel Pentium IV, 2.39 GHz, L1: 8KB L2: 512KB (16% Load)) ¤ Temperature: (Deactivated by user)
Hard Disks: (Total/Free: 847.65/510.12GB ¤ Total/Free space on: C: 74.5/17.23GB ¤ D: 74.5/74.43GB ¤ F: 698.65/418.46GB)
some script I found... maybe that'll help -
Mmm. Can you email me & I'll send you a new reg code?
Ok. Thanks. (thats the fastest forum comms i've ever had!)
haha, good. I had to wait 2 days for my register on this fourm to go through so I could post
Did you get me email?
I lost my program, info and other stuff in a hard drive crash and had to reinstall the program. When I open it to use I get a LONG list of errors begining with this:
file c:\program files/Badger soft/SVCD2DVD/MSVCP71.dll
HELP and thanks in advance. -
Do you have the file: msvcp71.dll in your system folder? This is usually c:\windows\system32.
If you do not have msvcp71.dll in your system folder copy it there from the SVCD2DVD folder. Then delete it in the SVCD2DVD folder.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I do, but it still kept doing the same thing until I deleted the copy in the SVCD folder. Thanks for the heads up!
Hey it's me again, my svcd2dvd still won't work. this is the error I get now when I turn it on (2.0)
Code:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NotSupportedException: Variable uses an Automation type not supported in Visual Basic at CodeLock._Secure.Initialize(String protected_file) at AxCodeLock.AxSecure.Initialize(String protected_file) at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/winxp/microsoft.net/framework/v1.1.4322/mscorlib.dll ---------------------------------------- SVCD2DVD Assembly Version: 2.0.1961.16804 Win32 Version: 2.0.1961.16804 CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe ---------------------------------------- System.Windows.Forms Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/winxp/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll ---------------------------------------- System Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/winxp/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll ---------------------------------------- System.Drawing Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/winxp/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll ---------------------------------------- DevComponents.DotNetBar Assembly Version: 4.8.0.0 Win32 Version: 4.8.1.0 CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL ---------------------------------------- AxInterop.CodeLock Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL ---------------------------------------- System.Xml Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.2032 CodeBase: file:///c:/winxp/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll ---------------------------------------- Accessibility Assembly Version: 1.0.5000.0 Win32 Version: 1.1.4322.573 CodeBase: file:///c:/winxp/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll ---------------------------------------- Interop.CodeLock Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog. -
I'm just shooting into a barrel here, but you might try uninstalling then re-installing .NET framework? Some of the errors it's throwing out seem to indicate that as a possibility
:P <== no expert, though! -
That worked. I was able to create and burn a dvd without problems. then I closed the program and now i'm getting the same problem and errors and it won't open. am I going to have to reinstall my .net framework every time I want to use this?
sheesh..that *is* weird. Maybe ChrissyBoy can come up with a solution.
Somtimes NET can get a corrupted file & it hoses up, but I'm not versed in
how to troubleshoot it.
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 17:28 -
SVCD2DVD Audio problems
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 6th Mar 2008, 11:53 -
SVCD2DVD Vista problems
By blondeguysteve in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Nov 2007, 10:35 -
SVCD2DVD 2.5 Problems
By mistalcote in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Aug 2007, 04:31
