This may be a stupid question and have probably been answered before but my question is i downloaded a file to which i was able to play on winamp, I want to burn this to a cd-r and everytime i play it on my mp3 player it says no disc or error? I have burned mp3's before to cd-r's without any problem but this particular file, i was able to transfer to winamp but will not record on cd-r, any suggestions? Thanks
It isn't a download from one of the MP3 sites that can only play on the PC that it was downloaded to was it?
I think Microsoft do/used to do that.Cole -
No i don't think so because I know some people were able to transfer it to their mp3 player.
I think i got my answer from my other post, since winamp plays mp3 this is in mp3 format and i would need to convert it to wave to burn to disc, easy cd creator does this right? when i look for the file to burn i guess i'll search for the file from winamp? am i right? how do i do this? what i did was when i used easy cd creator i dragged the file from my C drive which was not an mp3 file. Forgive me for my ignorance since i am very new at this. Thanks
it depends on your player, if you want to play it as an audio cd yes it must be converted to wav then burned to cd, if you want to put it on cdr as mp3 and your player can play mp3 like some panasonic then you burn it to cdr as data file.
How do I convert it to wave? Doesn't easy cd creator do this for you? Thanks
You don't have to. You can burn an mp3 to an audio cd with either cdburnerxp pro or burrrn, both are free programs.
Hope this helps.
RogThere are many ways to measure success. You just have to find your own yardstick.
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 07:01 -
Can I burn more audio (.mp3) files to my CD-R more than once?
By Nintendo Fan in forum ComputerReplies: 23Last Post: 25th Mar 2009, 21:10 -
I have 42 Mp3's for a total of 141mb, how come I can't burn all of it on cd
By jbitakis in forum AudioReplies: 16Last Post: 1st Feb 2009, 07:53 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 01:15 -
MP3 burn to DVD
By beforethedawn in forum AudioReplies: 1Last Post: 26th Sep 2007, 04:32
