Everything seems to go fine until I reach Step 3 vob2audio
I click on the voblist and find the first file, well it's the only file, but I wait the three minutes sometimes more.
then when I close it I recieve this message
Ligos splitter seems to miss an audio stream!
Use the audio vob-option in smartripper!
or use vobtools to delete first segment.
Can anyone help please, Thanks
well if that happens your okay if only the directors commentary is gone so i suggest you go on and rip the others and check if they are the Audio you want and if it oesnt have the Audio you want..thne you might try to use GrpahEdit but is a very complicated program
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>This is going to sound real stupid I'm sure but rip
what, still lost. -
For some reason Vob2Audio keeps doing this, why I stopped using it a long time ago... I'd suggest using Graphedit for the audio instead, it's not hard and there's a simple guide at http://digital-digest.com under Nicky's Guides.
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
How do I find my past posts?
By solarblast in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 19:29 -
ConvertxtoDVD encodes fine in past, now very slow
By brdhsby5 in forum Video ConversionReplies: 6Last Post: 10th Sep 2009, 14:51 -
Can not play DVD's past the intros.
By joeuu in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Aug 2007, 11:06 -
Hacking the Toshiba RD-KX50 or just getting past Mircovision
By gbann123 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th May 2007, 23:54
