Results 1 to 11 of 11
    Dec 2003
    united kingdom
    Hi, just re-installed nero, i used to burn 2 dvds at once with my 2 burners, but when i choose recorder, i cant drag/highlight both, as i could b4 a pc crash/re-install, any ideas ?? using version 6.6.0.13
    Thanks in advance
  2. Not really authoring. Moving you
    /moderator bugster
    There are 10 kinds of people in this world. Those that understand binary...
    Nov 2001
    Upstate NY
    Did you tick the "Use Multiple Recorders" box on the burn tab?
    Dec 2003
    united kingdom
    thats just it, its not there........
    Nov 2001
    Upstate NY
    My version is 6.3 something have you tried going back to a previous version?
    Dec 2003
    united kingdom
    on the *CHOOSE RECORDER* tab, both drives are there, plus the virtual drive, when i've set up b4, i could highlight 1 of my pioneer drives, then *DRAG* so that i could hilight them both, click ok, then i got a *Use multiple burner* check box, but i can drag to hilight both......
    i have not got another version to roll back to.....
    Nov 2001
    Upstate NY
    That isn't possible in my version. Have you tried:
    1. setting up your compilation
    2. hit burn button
    3. got to burn tab
    4 set to 2 copies
    5 tick multiple recorders
    Also can get older version here
    ftp://ftp.nero.com/software/neroburningrom/nero63125.exe
    Edit: fixed link
    Dec 2003
    united kingdom
    i know your trying to help, but..
    I DONT HAVE A BOX TO TICK FOR USING MULTIPLE BURNERS !!!!
    I CAN ONLY SELECT 1 RECORDER AT A TIME !!!!
    oh, and the link does not work....
    I just cannot understand why, at the choose recorder tab, i cant drag over both to select them, i could the last time i set nero up, thats how i did it, then i get the box to choose between using 1 or 2 burners.
    Nov 2001
    Upstate NY
    OK sorry I can't help with that version. If you want to try an older version:
    ftp://ftp.nero.com/software/NeroBurningROM/
    Edit Link fixed
    Dec 2003
    united kingdom
    Nov 2001
    Upstate NY
    Then just type it in and go there the file is actually there
