Results 1 to 9 of 9
  1. Member broth's Avatar
    Apr 2005
    Germany
    hey,
    i have 2 (s)vcd images on my hdd which I want to fit on one DVD...
    I tried extracting the movie part and burn them but my dvd standalone player wont play it then (most likely because after that the structure is damaged)!
    I have some software like VCDGear, Isobuster, etc etc but it still does not work for me. Please give me step-by-step assistance...
    THANKS A LOT!!!
    www.svcd2dvd.com or dvd-lab and make a dvdsvcd.
  3. Member Paul_G's Avatar
    Welcome to Spoonfeedhelp.com
    There is guides on this site what clearly explain step by step on how to put (S)VCD mpegs on to a DVD.
    <-------- Guides.
  4. Member broth's Avatar
    Apr 2005
    Germany
    i tried the guids but I have not been lucky enough to find one from an SVCD image to DVD....
    i hope you make me more lucky :P
  5. Originally Posted by broth
    Svcd2dvd.
    Take the bin+cue put into svcd2dvd press go and wait a few mins and hey presto you have the dvd folders ready to burn.
    Unlead will also do it i think, but you need to extract mpgs from the images. Thats easy look in the guides/tools for the program to do it. (hint (iso buster)) Select the mpegs and off you go.
    Not bothered by small problems...
    Spend a night alone with a mosquito
  6. Member broth's Avatar
    Apr 2005
    Germany
    can somebody please give me a link for a free trial for svcd2dvd....?
    the link at videohelp costs money right away....or even better: send me alternate easy-to-use programs to do the job...
    thanks!!!!!!!!
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  8. Member broth's Avatar
    Apr 2005
    Germany
    mmh, another instance is already installed....what the f@ck?!?! i just dont get it running at all
  9. Member broth's Avatar
    Apr 2005
    Germany
    thanks Chrissyboy for you PMs and great amount of help!!!!!!
    SVCD2DVD works perfect
