Ave,
I recently installed a new pack of Codecs to update Codecs on my system, and that's probably the last change that i can remember. I have been encoding/authoring DVDs for a long time now, over 200 done, this is the first time i'm seeing this problem.
As far as i can remember, after installing the Codecs, i encoded 2 videos to DVD... and both have the same problem... when you play them, you can spot the frames moving one by one... it's not smooth motion, it's like each frame freezes and then moves on. It's not very slowly either, it's hard to notice, but it's noticeable by anyone... i call it Freeze Framing, i don't know if there is a technical word for this.
Now i don't know if this is because of the new Codecs i installed or what. There was nothing different i did with the encodings & authoring. They were simple NTSC AVI videos i encoded to NTSC DVDs. Just like i usually do.
Can anyone shed some light?
Thanks,
Mickey
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it! -
Originally Posted by Baldrick
I was planning on doing exactly that. I think all i need is DivX, XViD, 3Vix codecs for the video. I do have GSpot.
I saw a K-Lite Codec Pack.. i was wondering if i should install that. I don't know, maybe i should just go with the Individual.
Thanks,
MickeyI don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
Photo Framing Software?
By Kamaljeet Dhiman in forum ComputerReplies: 2Last Post: 28th Dec 2010, 09:36 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 16:15 -
Edited MPEG2 Files Retain Distorted Vertical Framing Upon DVD Burning
By cyberboy in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 19:13 -
Svcd2dvd Freeze's
By gazinc in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 18th Apr 2008, 13:00 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 04:12
