Can i link my SKY box up to my PC so i can record some programs. Then i want edit the file into smaller sections.
Yes, you need a capture card in the PC and then connect the VCR out of the Sky box to the capture card (for composite). If you want a higher quality S-Video or RGB connection you need to use the TV-Out connector.
There are 10 kinds of people in this world. Those that understand binary... -
Get a Skystar 2 DVB PCI card /or similar/, watch free to air and Pay TV channels and record directly into MPEG2 on your PC. The card supports satellite DSL as well.
Check out www.technisat.com for more info. There are tons of web sites dedicated to this in Europe.
Enjoy! -
Thanks for the reply but can you recomend a good card and do i need any other software?
recording SKY+HD
By snadge in forum DVB / IPTVReplies: 0Last Post: 26th Feb 2009, 13:15 -
Recording from Tata Sky
By planetx in forum Capturing and VCRReplies: 1Last Post: 7th Nov 2008, 22:07 -
Recording to DVD from Direct TV's system of organizing saved programs
By sarainelkins in forum DVB / IPTVReplies: 2Last Post: 15th May 2008, 10:51 -
Sky + And/Or Sky HD Recording To Pc With DAZZLE
By akenny01 in forum Capturing and VCRReplies: 0Last Post: 7th Mar 2008, 19:02 -
Sky+ recording to dvd help!
By dollydoodledumplin in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 01:25
