My SVCD2DVD v2 9b run well. More and better options than 1.5. But when it finish i try to burn it with COPY2DVD i get an error. I don't have problems copying my old Video_TS files made with SVCD2DVD 1.5?
ERROR
Title Program chainTable: End address 305 doesn't match table size 314(c:\workplace\IFO\u_\FO.PAS,line4717)
Please help!![]()
Results 1 to 9 of 9
Not sure what the copy2dvd error means. Are you using the latest version of copy to dvd?
Let me try to expain further. I can burn other video files(bin,iso,mpeg) with any of the programs;Nero, Copy2dvd & DVD Decrypter. When i use the Quick DVD & Burn feature in SVCD2DVD I get the error message
Media Unknown. Please insert writeable media......(with an explanation of what are writeable media)
When i use Quick DVD option in SVCD2DVD and try to burn the Video_TS file seperate it give me the table error message that i mentioned before.
I know it have to be the way SVCD2DVD is producing the Vieo_ts file, i think? My drive burns with other programs and other types of video files. Even the older video_ts files from SVCD2DVD 1.5 burns with no problem.
Maybe there's some setting i need to do? re-install net.framework when upgrading to v2 9b? i don't know please heeeellppp... i been fine with 1.5 but the pal>ntsc conversion feature is just what the doctor ordered. -
Can the VIDEO_TS folder be burnt with Nero Express?
After i did all of this. I finally got SVCD2DVD to work with DVD Decrypter. But it creates ISO's file which take away fexibility and versatelity. Such as, Three movies on a dvd. then being able to switch movies in and out to create another different set of three. I still could use your help with Copy2DVD capatibility with SVCD2DVD
Hey ChrissyBoy. The process with DVD Decrypter is way tooo long and nor reliable. Have you figure out what could be causing the table error? Please i still need help here. Thnxs
Can you send me a log of a run that produces a VIDEO_TS folder which Nero can't process?
all it meens is the info is too big to fit onto a dvd use dvd shrink to make it smaller then try to burn it
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 19:04 -
Burning from Video_TS
By Wanderlustus in forum Authoring (DVD)Replies: 14Last Post: 10th Oct 2009, 11:15 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 00:10 -
Toast 9 Video_TS burning + aspect ratio
By brumos in forum MacReplies: 1Last Post: 29th Jul 2008, 07:34 -
trouble authoring mpg files made in Adobe Premiere Elements 3.0
By compaqted in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2007, 23:14
