Hi, i'm encoding a 640x480 file with hardcoded subtitles, when i burn to dvd, the subtitles are almost off the tv screen. Is there a way around this?
I'm using NTSC format, with tmpgenc xpress.
Hi meccaho,
There is a part of the TV screen that cannot be screen because it is covered by the moulding which holds the screen in its housing - this is called the "overscan" area.
You need to figure out - most probably by educated guessing and "trial and error" - how much of the picture is covered by the overscan.
Having not needed to do this, I can't reliably tell you how to take the overscan into consideration. But this, in effect, is what you're asking - I just thought I'd give you some background.
Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
When you resize, resize to a vertically smaller size (~16-32 px) than full DVD res. Add black bars top & bottom to compensate upp to full DVD vert res. How to do that depends on what you use, but I recommend VirtualDub or AviSynth (frameserving to your encoder)
/Mats
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 20:26 -
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 12:36 -
Cutting subtitles with Avisynth script...?
By Kalekulan in forum SubtitleReplies: 0Last Post: 8th Jun 2010, 15:34 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:44 -
TMPGEnc DVD Author 1.6 cutting a movie short?
By FizzFozz in forum Newbie / General discussionsReplies: 0Last Post: 21st Jun 2008, 12:20
