Hi,
When I back up a DVD, I usually use VOBBlanker to get as much space as possible, sometimes making still menus and sometimes not. Either way I always disaggle the menu button that leads to blanked files. I was able to find this guide for doing this with a still menu: http://dvdguides.netgeekhosting.com/guides/edit_menu/ It works perfectly fine with the still menus. It also works good with disabling the button on a motion menu that I havent needed to turn into a still. The problem is when it talks about editing the BMP to erase the words "Special Features" or whatever the words for the button were. Once again, it works fine with stills, but how will I get it to work for a motion menu? So that the words are gone for the entire animation of the menu? I hope my question makes sense. I tried to edit the picture and get rid of the words for the entire motion menu using the guide, but since the BMP is a still shot of the menu, it doesnt erase the words for the duration of the menu. Is there a way to do this? Thanks.
Results 1 to 1 of 1
Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
Change and delete some button in motion Menu?
By p_samimi in forum Authoring (DVD)Replies: 4Last Post: 7th Sep 2009, 16:52 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 12:55 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 23:06
