I'm captured a home video into mpg and would like to burn it on a DVD so that I can play it on my DVD player. Can nero 6 do this and if so do I need to convert the mpg into anything? I used WinDVD Creator to capture and WinDVD can automatically burn them on DVD for you, however I was wondering about Nero 6.
If the MPEG is DVD compliant and has been authored to VOBs, etc., you just select 'DVD-Video' in Nero and drop the files into the VIDEO-TS folder and burn. If Nero wants to reformat it, then you did it wrong.
So Nero 6 can't automatically convert an mpg into a DVD ready to burn?
I have to use a program then to convert it to Video-TS or ISO image then? -
I think you need NeroVision Express for that using the Nero system. But I would download a trial version of TMPGEnc DVD Author and try that instead to author. IMO, Nero is fine for burning, but for authoring and encoding it's not that great.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
nero crashed during burn
By mr-scarface in forum Authoring (DVD)Replies: 13Last Post: 14th Jan 2009, 23:41 -
Can't burn video TS with nero
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2008, 03:19 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
