I've got a movie in avi format that is split to fit on 2 CDs. I want to convert this to DVD. I've joined the avi files using VirtualDub (using this guide, including the keyframe bit: http://www.dvd-guides.com/content/view/14/59/). My concern is the subtitles. They are split into 2 CD mode as well (.idx & .sub files for each CD). What is the best way to join these and convert to a format suitable for DVD? Am I going to end up with sync problems because I joined the avi?
Thanks guys.
"The best way to join these and convert to a format suitable for DVD?"
Subtitle Workshop
"Am I going to end up with sync problems because I joined the avi?"
No if you follow the help file instructions - you have several options. -
From the description:
"Subtitle Workshop is the most complete, efficient and convenient subtitle editing tool. It supports all the subtitle formats you need(not sub/idx use subrip) and has all the features you would want from a subtitle editing program."
From that I was under the impression that it didn't support the format I have.
EDIT: It definitely doesn't work. I just tested it out. -
Get the subs in .srt format. Use Subtitle Studio to join, using length of part 1 video as delay for part 2 subs.
/Mats -
Originally Posted by modtang
Just use Subrip to convert your sub/idx to .srt.
Then use Subtitle Workshop to join.
VHS transfer - ADVC-300 with TBC-1000 and BVP-4 - Potential Problems?
By OldMedia in forum RestorationReplies: 9Last Post: 10th Aug 2010, 01:33 -
Problems w/ Divx Converter + Subtitles @ PS3
By RJARR in forum Video ConversionReplies: 7Last Post: 19th Aug 2009, 07:49 -
Joining 2 Subtitles
By ashwin.terminator in forum SubtitleReplies: 2Last Post: 18th Apr 2009, 06:30 -
sony RDR-HX750 problems with divx-subtitles
By eclecticus in forum DVD & Blu-ray RecordersReplies: 0Last Post: 10th Apr 2009, 14:39 -
No Subtitles after joining 2 avi files
By kinghlg in forum SubtitleReplies: 10Last Post: 12th Mar 2009, 05:36
