Video is a TV capture in MPEG2 and using VirtualDub-MPEG2/MOD to convert to xvid. Basically the video went from a landscape to a portrait. Any idea why this happens and how do i rectify the problem?
Before in Windows Media Player:
After importing into VirtualDub:
It looks like the original was actually encoded as half-D1, something that wmp wasn't smart enough to pick up on. Virtualdub has done the right thing. To see how it should look in the preview, right_click and select 4:3 from the menu. When you resize it for conversion (assuming you were going to), the problem will go away.
Read my blog here.
i tried the selecting 4:3 on right click b4. Apparently it looks fine in VirtualDub but still exports the video "squashed" portrait style. I went into the codec configuration to set/change the video size/ratio but still got the same result. whats gives?
yeah~ worked after the resize filter as u instructed! but i had to use full processing mode to access the filters option. Is this normal?
ohh on another matter, why is my "append segment" function grayed out?
Thanks!
Need help in importing MP4 files in VirtualDub...
By hash13 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2010, 07:29 -
Video Dimensions Question (720x480x32)
By Hass860 in forum Newbie / General discussionsReplies: 6Last Post: 18th May 2010, 09:55 -
bad video dimensions information
By bl88drg in forum Newbie / General discussionsReplies: 18Last Post: 28th Jan 2010, 22:02 -
Reducing framerate and video dimensions doesnt decrease filesize?! WHY?
By boskins in forum Video Streaming DownloadingReplies: 4Last Post: 12th Mar 2009, 08:35 -
Video/pic quality - Bit Rate, Dimensions...?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 5th May 2007, 12:02
