How come I cant burn a dvd with the same quality an original Xvid file/avi has. I have to encode it to mpeg-2 and the quality seems to diminish!!!!!
Someone tell me a better way to do this!!!!
Vegas , DVD Architect ,TMpgenc Plus , VirtualDub.
I would use Tmpgenc Plus to convert from Xvid to Mpg2 and then Author with Tmpgenc Author if thats what you have. -
There is alot more info you will need,Try searching and reading. when you hit a bad spot just post back.
If you resize the original up to dvd sepc, it will soften. Unsharp masks will help you get some detail back, but too much and the image degrades again. Resizing also makes some problems in the original Xvid, such as blocking, more noticable. Bottom line, it will never be DVD quality, and it will never be better than the Xvid original. Best you can hope for is as good as the source.
Read my blog here.
Problems encoding a quality streamed video
By Berek Halfhand in forum Video Streaming DownloadingReplies: 7Last Post: 13th Feb 2009, 22:24 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 11:08 -
AVI to DVD quality problems
By Stetsondolly in forum Video ConversionReplies: 20Last Post: 11th Feb 2008, 21:23 -
Camcorder-PC quality problems
By Brazil-Ben in forum Capturing and VCRReplies: 2Last Post: 5th Oct 2007, 18:45 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 23:53
