I heard that you need to follow a different procedure when ripping and converting this movie as it has some type of protection on it. Is that true?
I think this is really old news. Use smartripper and you should have no trouble.
Macros -
This is true but most of the newest ripper has fixed the porblem but the SmartRipper is the best Ripper for the Matrix but remember only pick one angle
/me was unaware it had multi angle. or is it only in the ntsc version? then again the last timei saw it on dvd must have been two years ago, and that player probably didnt support multi angle....
which bits are multi angle? -
"Unbreakable" is another one... serious multi-angle thing going on...
I also prefer Smartripper, it never fails for me. You can literally just check off an angle and "GO". -
naw....T2 ultimate edition is prolly the most multi-angled shit i've come across so far....smartripper couldn't even unlock the drive....claddvd couldn't completely remove all the multi-angles, but dvddecryptor (with multi-angle processing) was able to rip it correctly thou...
Matrix Character SubRip
By Anonymous171 in forum SubtitleReplies: 0Last Post: 7th Apr 2012, 19:38 -
Matrix DL DVD+R, Any Good?
By Des in forum MediaReplies: 12Last Post: 23rd Feb 2010, 14:21 -
What if the Matrix ran on Windows
By freebird73717 in forum Off topicReplies: 3Last Post: 12th Nov 2008, 19:29 -
Custom Matrix file
By Maikeru-sama in forum Video ConversionReplies: 2Last Post: 16th Jun 2008, 22:15 -
matrix video clip
By theewizard in forum Newbie / General discussionsReplies: 2Last Post: 27th Feb 2008, 00:22
