How do you say this? 4:3
Is it 4 by 3? 4 to 3?
Thank you.
Depends who you are trying to impressOriginally Posted by skebenin
Hi,
The notation "4:3" is describing a ratio, often said (in my experience) as "A ratio of 4 to 3", shortened to "4 to 3".There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Need Video card suggestion and terminology help (solved)
By gll99 in forum ComputerReplies: 9Last Post: 14th Aug 2011, 03:21 -
an alternative question about terminology
By compusic in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 02:37 -
Correct Terminology for a menu frame that shows a clip from the movie
By gayclarke in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 09:19 -
Newbie looking for correct terminology so I can effectively search
By redraif in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2007, 15:15 -
Correct Terminology for authoring?
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2007, 03:45
