    Jun 2004
    Detroit, MI (USA)
    I havent used video studio 7 in a while, I am pretty sure i didnt have this problem before. But for some reason when i try to capture now. It only captures at 320x240. I have gone to the PROJECT PROPERTIES and set it to AVI 720x480 @ 29.97 fps.. i go to capture. i set the capture format to AVI .. my VCR is connected to PC via a DAZZLE.. but when i do a test run. The video i capture comes out in AVI format like it should, but its in 320x240.. what would have altered this??
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Which standards will the Dazzle support in realtime?
    Try using the VS7 presets "VCD 352x240 MPeg1 (start here)", "DVD 720x480 MPeg2".
    You will need a fast computer for realtime capture to MPeg2 and even faster for analog to DV capture from a VCR.
  3. I'm a Super Moderator johns0's Avatar
    canada
    What model dazzle do you have?If its dazzle 80 then it can only capture up to 320x240.
    Jun 2004
    Detroit, MI (USA)
    Originally Posted by johns0
    What model dazzle do you have?If its dazzle 80 then it can only capture up to 352x288.
    then i am gonna have to redo some of my home movies then cuz i prolly made them half ass..lol
    The version i got doesnt say 80 on it at all. I have seen that one before. Mine just says Dazzle Fusion © 2003......which one is the best these days? i have had this one awhile... been working fine for what i need.. i coulda swore it capture before at 720..
  5. Member edDV's Avatar
    Mar 2004
    home movies = important family recordings from VCR?
    Look seriously at the Hauppauge PVR-250 http://www.hauppauge.com/html/wintvpvr250_datasheet.htm
    Jury still out on the PVR-150
