    May 2005
    Toronto
    Hey everyone
    i seem to having trouble with the new DVD writer i got today
    it will only play some dvds and wont play others
    for example i put in last samurai in the drive it plays fine
    but when i put in say matrix it spins for a while but nothing happens
    i go to the drive and open it
    nothing is in it
    nothing pops up when i put it in
    im hoping some one here can help
    thnx in advance
  2. Could be weak laser, maybe its a DOA that slipped through control. Anyway, what kind of drive is it and whats the firmware version?
    Edit: Forgot to ask, does it burn DVDs?
    May 2005
    Toronto
    it is a sony dvd writer it can burn dvds and i dont know about the firmware and what is DOA
  4. DOA = Dead On Arrival, as in the drive may have already been broken when you recieved it.
    You can determine the specific model and firmware version of your drive using several tools, including DVDInfoPro.
    -drj
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  5. If its one of those new low-price Sony, like DWD23, it could be hard to get any help, not many people have them yet and little is known about them still. It could be a problem others have experienced, with Windows or something, lets hope someone can help. For now all i can suggest is to insert one of those disks that dont work and then open DVDDecrypter or DVDInfo to see if they can retrive any info about the disk. If the disk can be read there i would think it could be a problem with your Windows.
    May 2005
    Toronto
    i tried both of those programs and it couldnt read the disc
  7. Then there is a good chance your drive is broken. I had similar problem with a Nec, first it stopped reading most original disks, so i turned it in, they said "weak laser", and i had to take it back without fixing as it had no warranty. Then later it stopped writing DVDs and also stopped reading burned single layer DVDs. Now it reads only CD and CDR.
