I have 2 svcd files they have a frame rate of 23 fpm.
I would like to convert them to 29.97 fpm so i can put them on a dvd.
The way i had always done it before was to convert them with TMPGEnc encoder. which usually takes me anywhere from 8-15 hours. and with that im really just changing the fpm rate.
Is there a quicker way to do this?
Yes, there is a quicker way. Extract the mpegs from the SVCD's and add 3:2 pulldown flags with pulldown.exe or DGPulldown.
They still will not be DVD compliant though because SVCD is 480x480. DVD requires 352x480 or 720x480. Also SVCD audio is 44.1khz and DVD requires 48khz.
(NOTE: Resolutions assuming NTSC)There are 10 kinds of people in this world. Those that understand binary... -
thanx bugster for the tip.
and yeah for the screen resolution as well. its been a long long week.
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 15:55 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 15:13 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 11:11 -
Scriptable tool to change AVI frame rate metadata?
By FurrTheBear in forum Video ConversionReplies: 4Last Post: 8th Jan 2010, 02:43 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 06:21
