I just picked up a few 50 packs of Staples' brand DVD+R's for about $8 each. I think it's a one week offer. I had to go to 2 stores though, the first was sold out. I'll give them a try and tell y ahow they turn out.
Results 1 to 30 of 35
also very interested in this. Who actually makes these DVDs? The had +r and -R are they both made byt the same manufacturer?
According to this site they are as follows:
DVD-R 8X - CMC MAG
DVD-R 8X - FUGIFILM 03
DVD-R 4X - OPTICDISCR004
DVDR-RW - OPTICDISCW002
DVD+R - 8x - MBIPG101R04
DVD+R - 4x - OPTODISCOR4
The down side of this is that they have only one to five comments on each of the types.
It is a good price for expermentation tho. -
15.9 cents a disk. He thinks to himself, How low can they go!
Anyway I just tried out the +R IO bought and they seem to be working OK.
According to DVD Decrypter they are, Disc ID: CMC MAG-E01-00
I'm thinking about trying for more tomorow. They had a decent stock when I was there this morning, Once I found them. They weren't on the shelves with the rest of the media. They were on an isle end.
I may try the -R this time.
Cheers -
damn well CMC isnt considered good media. I was thinking of making backups of all my movies but Im sure these dvds will be unreadable after about a year, and I def. dont want that happening. Now the fuji is a different story. Any way to make sure the -R we get are fujis? Any difference between the CMC -Rs?
I just bought a pack myself, didnt try any of them yet, but I've never had any problems with cmc media, or any media for that matter, maybe I'm just lucky. Anyways there was this old couple that were looking at them, there was probably 10 packs there, I took one and went to look around the store, when I came back I saw the old couple took all but 1 pack! I hate ppl like that, never save anything for others, they're probably going to sell it on ebay. That just really got on my nerves, I could only buy 1 pack anyways, otherwise I would have said something.
CMC is considered good media by myself and many others, I've burned close to a thousand on 3 different burners and they are excellent discs. I have several hundred that are about 2 years old and they all still play flawlessly and scan with low errors.Originally Posted by zgrm100
Now Fuji IS a different story, the Fujifilm media coded discs I've tried don't burn as well as my CMC media. They burn decently and play fine most of the time, just not as low of PI/PO errors and the transfer rate tests aren't that good. But they usually play OK. I've used alot of the 8x CMC AE1 discs and they burn great on my burners, but the AE1 discs seem to struggle on some burners until the firmware is upgraded.
This is an awesome price for these discs, of course I don't have a Staples where I'm at....
Well I just opened up the -R from staples and it has a media code of: Manufacturer ID: CMC MAG. AE1
So it looks like both the +& - here in New Jersey are CMC. FWIW The Somerville NJ store had plenty left this Monday morning. At these prices it totaly isn't worth it on a per Gigabyte basis to use CD-Rom disks.
Cheers -
I just picked up 2 of the +R spindles. They are made in Taiwan. I opened one of the spindles and the inner hub has the following serial number - CPDR47G-CAEWP13-108 0305
DVDIdentifier shows the disc as the following..
Disc = [DVD+R:CMC MAG-E01-000]
Unique Disc Identifier : [DVD+R:CMC MAG-E01-000]
Disc & Book Type : [DVD+R] - [Not Available]
Manufacturer Name : [CMC Magnetics Corp.]
Manufacturer ID : [CMC MAG]
Media Type ID : [E01]
Product Revision : [Not Specified]
Blank Disc Capacity : [2,295,104 Sectors = 4,482.6MB = 4.38GB (4.70GB)]
Recording Speeds : [1x , 2.4x , 4x , 6x-8x]
[ DVD Identifier - http://DVD.Identifier.CDfreaks.com ]
And from DVDInfoPro -
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID CMC MAG E01
Media Product Revision Number 00h
Format Capacity Blank Disc
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Manufacturer Rated Speed 8.0x 11080KBps
Available Write Descriptor CLV 12.0x 16620KBps
Available Write Descriptor CLV 8.0x 11080KBps
Available Write Descriptor CLV 6.0x 8310KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Linear Density Blank Disc
Track Density Unknown
Number of Layers 1
Complete Media Code
00000000 01 02 00 00 A1 0F 02 00 00 03 00 00 00 26 05 3F .............&.?
00000010 00 00 00 00 00 00 03 43 4D 43 20 4D 41 47 00 45 .......CMC MAG.E
00000020 30 31 00 38 23 54 37 10 02 38 6A 02 88 67 15 15 01.8#T7..8j..g..
00000030 0B 0B 08 08 01 19 1B 0C 0C 0C 0D 01 00 00 00 00 ................
Same ID as the Phillips 8X +R discs I picked up a few weeks ago.. those burnt pretty well. This is a good deal by Staples.NEC 3500AG - Firmware 2.TG
LiteOn 16P9S - Firmware FS09
Taiyo Yuden 8X, FujiFilm 8X YUDEN000T02, Phillips 8X CMC MAG-E01-000.
DVDDecrypter, DVDShrink, DVDFab, Nero 7
Hauppage WinTV PVR 150
Dscaler, TMPGEnc Plus/Author, Canopus ProCoder, CCE. -
The staples-brand disks (-r) that I have are:
(from dvd_Identifier v3.6.3.1)
These work flawlessly in my dvd recorder (220-s) unit.Code:------------------------------------------------ Unique Disc Identifier : [DVD-R:FUJIFILM03] ------------------------------------------------------ Disc & Book Type : [DVD-R] - [DVD-R] Manufacturer Name : [Fuji Film] Manufacturer ID : [FUJIFILM03] Blank Disc Capacity : [2,298,496 Sectors = 4,489.3MB = 4.38GB (4.71GB)] ------------------------------------------------------ [ DVD Identifier - http://DVD.Identifier.CDfreaks.com ] ------------------------------------------------------
I've never had a problem yet.
@ $8 dollars for 50 *is* a great deal, (mine cost $14.99 for a 25pk)
I'll have to check them out.
(I like to just pop in an -R disk for quick tv shows - for the heck of it. And
a 50pk @ $8 bucks sounds like not to bad a deal to waste on quicky records)
Thanks for the heads up on this price break-through.
-vhelp 3346 -
Same ID i got for my dvd-r's from the flemington, NJ store: CMC MAG. AE1Originally Posted by TBoneit
Im gonna test em soon, and maybe report back if im not too lazy
Note: I also got a linksys wireless-b router for $42 bucks with a $40 easy rebate, plus a manufacturers rebate for $20... so i might end up making money if i get the manufacturers rebate too
link - http://forums.slickdeals.net/showthread.php?threadid=100731&postid=1186141#post1186141 -
I was actually able to get the 50-pack of Staples DVDs for only $4.35 (thats only 9 cents per each DVD!).Originally Posted by hecklernumber1
Here's how (from FatWallet.com):
1) go to Staples.com
2) choose a Chicago zipcode (ie, 60602)
3) look at their weekly ad ... the 50-pack DVD is $4.94 ... print off this ad
4) go to http://www.staplescentral.com/customerAppreciation/customerappreciation.htm to print off a special 12% off coupon
5) take both printouts to your nearest Staples store, for a store price-match and coupon for 12% off that.
6) net total is $4.35 per 50-pack!
They are the 8X CMC type. Hope this helps! -
oh cool thanks. Well printed out everything brought it to a staples and the manager wouldnt price match because it is a grand-opneing special since they just opened 2 new stores in Chicago. He did take the 12% off though so thanks.
Sorry to hear they would not price match. However, that is against their stated price match policy.Originally Posted by zgrm100
If you check http://www.staples.com/content/Help/Using/general_match.asp , it states :
"What if I find a lower price at Staples?
If you find a lower price in one of our stores, catalogs or on Staples.com®, we’ll match the lower price, however the additional 10% of the price difference does not apply. If an item is marked "clearance", the clearance price is only valid for in stock product that is marked at that clearance price."
I would see the store manager, show them their policy, and have him give you the price difference. Good luck! -
holy sh*t. I did speak to the manager the guy was a total As*hole he tol dme 20 times that since its a new store he wont match it. Now I am pissed he simply told me that he wont match it at all grrrrr.. Good thing I have the reciept. What should I do if he still doesn't want ot match it? When I asked him what the matching price policy is he said that it says they DO NOT price match prices where the store is a new "grand opening"
Well actually he was right. IT says that on grand opening the price matches is not available.
Which items and services aren’t available for price-match?
We don’t match our store prices to those on other companies’ web sites. We don’t price match our third-party providers' products and services (e.g., Sprint® service, tax preparation, payroll services, and custom printing), items sold on auction sites or at local or special events (e.g., grand opening, anniversary or liquidation sales). We don’t price match taxes and typographical errors. -
I would ask him to SHOW you where in the price match policy that they do not price match Staples "grand-opening" stores. Then show him the price match policy that you printed off (or give him the above link where the policy is located) where it specifically states "If you find a lower price in one of our stores, catalogs or on Staples.com®, we’ll match the lower price".Originally Posted by zgrm100
The way I see it, you are covered in all three areas: 1) they are selling the DVD pack for $4.94 at "one of their stores", 2) you are presenting a catalog page of the $4.94 price, and 3) you found that $4.94 price on Staples.com.
If the manager still will not accept that, I would mention that you will report him to the main Staples headquarters, and follow up with reporting him to the headquarters. Get his full name and store number. Staples wants satisfied customers, and frown upon managers who cannot keep their customers happy. And usually, they will give you something extra (discounts and such) for all of your trouble. -
That specifically applies to other sellers or stores outside of Staples. The grand-opening mentioned applies to other stores, not Staples grand-openings.Originally Posted by zgrm100
hmm it doesnt neccesarily say 3rd party though. It start the next sentence saying that things arent covered are local, and special events such as grand openings... I will try though.
Tomwil, thanks so much! I went back today armed and ready and it was a different manager who simply refunded yesterday's purchase and I bought everything again at the new price. Thank you soo much. Now I just hope these suckers burn!
Well, i picked up 2 spools of these discs yesterday in NYC.
Burned a few discs in my Memorex 4x dual format unit, with
no problems.
However, havent been able to get any to burn in my Pioneer
a09, i keep getting errors before burning starts.
Anyone esle have any issues with these discs NOT burning?
I'm using Dvd Decrypter in both places.
Win -
What you ppl using to determine the error rates on their burned disk? I'm using the DVD+R CMC on a Plextor 708 (FW1.1) and Nec 2500, so K-Probe (Lite-on) isn't a option. I'm not sure how well these disc burn at 8x. I've burned about 20 discs so far on my Plextor, I've had one disc write fail at the region where 4x turns to 8x. And I've had two disc w/ small gaps btwn the area of 4x and 8x.
Well FWIW, I've been using these since last sunday (1st day of sale) and they all play fine even when filled out to the edge. I tend to watch the compare speed when it does a data verify and if I see a dip in speed then I look further.
Has anyone used these discs with a Pioneer A09, as they wont work for me. They give an error message before
burning is started.
Win -
Have you tried updating the drive's firmware?Originally Posted by winman42
Well, i have 1.17 firmware, which i 'think' is the latest.
Gonna do a search to see if thats still true.
Win -
Well, i was wrong, 1.40 is the latest, which i'm going
to install in a bit, Wish me luck, and thanks for the
tip.
Win
STAPLES DVD-R Discs
By Frank-0-Video in forum MediaReplies: 8Last Post: 7th Jun 2011, 18:26 -
how do i rip special features off a dvd?
By username1 in forum DVD RippingReplies: 4Last Post: 6th Apr 2010, 19:18 -
Venice V36 - Special DVD Player
By its95 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Aug 2008, 17:09 -
DVD special feature - music player?
By NotSoEasy in forum Authoring (DVD)Replies: 1Last Post: 23rd Jan 2008, 03:49 -
Special DVD creation procedure
By Nick/Athens in forum Newbie / General discussionsReplies: 9Last Post: 29th Nov 2007, 00:13
