I have recently purchased an LG RH4920 DVD & HDD Recorder and in my enthusiasm to get the thing working only skimmed the manual before kicking off ops. The result of this haste was that the video/audio to both the HDD and DVD-R and DVD-RW were out of sync.
Before raising hell with the supplier I took a timeout and reread the manual a little more carefully and to my embarrasment found a small, not very prominent section, regarding setting the machine's Country Code which has surprised me a little - I was unaware that DVD recorders were country specific. Emblazoned on the front cover of the Manual is "Region 2" and that's it. On going through the setup again I reset the recorder from the USA to my own country and now it works like a dream.
As I don't have to input a 'Country Code' when backing up or making movies on my computer, why is it necessary when recording TV input on a stand-alone DVD recorder?
I'm curious and would appreciate any enlightenment.
Thanks in advance.
Just a guess, but it may well change something related to the broadcast TV standard used in your Country. Region 2 (with respect to DVD region coding) can be PAL or NTSC. What do you use where you live?
There are 10 kinds of people in this world. Those that understand binary... -
Isn't the country code just for your convenience, to provide localized menus and such, and record in the correct format (PAL/NTSC)?
/Mats -
Yup, I guess so.
Just thinking, tho', if I was writing a User's Manual it's the kind of information I'd put on Page One. It would have saved a lot of bad language around this house.
Mind you, like many, I don't 'do' operators manuals very well!
Cheers -
What?
I read manuals instead of novels - just love 'em! Half the fun of getting some new gizmo is plowing the manual - preferably in some language where you have to have a dictionary near by
/Mats -
You switched it from NTSC to PAL then. Surprised it recorded anything at all if you were feeding it a PAL signal and it was expecting NTSCOriginally Posted by zulusailor
He switched the OUTPUT....not the input. Quite a few DVD Recorders will record either PAL or NTSC as long as the disc is brand new. I've never heard of a DVD Recorder that can convert while recording.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Trouble playing ripped DVD with Windows Media Center 2005-bad country code
By nzdreamer55 in forum DVD RippingReplies: 3Last Post: 6th Mar 2010, 10:28 -
Region Code Samsung ht-bd1220 - Code does not work
By mhschenk in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Oct 2009, 14:44 -
Country Code is not set but ...
By LLavelle in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2009, 17:12 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42
