ok everything was fine till about a month ago. then all of a sudden my games lag online. i did a line quality test over at dsl reports and get 100% loss on i think 6. here's the line for that:
http://www.dslreports.com/quality/nil/1735051
so is this a line prob or computer prob? and how would i go about fixing it?
100% loss on that test (a trace route) means that the destination is blocking icmp packets/pings used for trace routing. It appears YOU are the destination, so you must have some sort of firewall installed or your ISP is blocking pings/icmp packets - no worries, best case actually; safest condition. As for overall response time, 58ms isnt too shabbyOriginally Posted by hellbringer
Have you considered the fact the servers you play on are just laggy w/many users?
Otherwise, the first thing I would do is ping my gateway. If that response time sucks, then you can complain to your ISP about your connection. Anything beyond that, unless you're paying $10,000/month for your connection, your ISP probably won't/can't do anything about it. Chock it up to general 'net traffic.
Computer turned laggy? (click for more details)
By PurkkaPoika in forum ComputerReplies: 12Last Post: 12th Feb 2012, 12:39 -
Laggy .MOV playback in Virtualdub
By a1ienz in forum Newbie / General discussionsReplies: 7Last Post: 16th Nov 2010, 03:47 -
How to fix choppy / laggy video? (no hardware lag)
By doomed9 in forum RestorationReplies: 6Last Post: 12th Jan 2010, 20:58 -
Conversion problem - Laggy (choppy) video
By yaang in forum Video ConversionReplies: 3Last Post: 4th Nov 2009, 13:36 -
MKV with srt = laggy (?)
By therock003 in forum Software PlayingReplies: 5Last Post: 15th Jul 2008, 14:18
