I'm trying to extract/convert the audio track from a DVD to MP3. Is there a freeware program that will do this? Thanks.
Results 1 to 13 of 13
<<< Tools - Audio Encoders
Should help you.Not bothered by small problems...
Spend a night alone with a mosquito -
Hi-
Yes, it's called DVDDecrypter. Set it up in IFO Mode, highlight the PGC you want (the longest is the default), hit the Stream Processing Tab, tick the Enable Stream Processing box, deselect all the boxes except for the audio stream you want, highlight it, tick Demux, choose a Destination folder, and hit the green triangle to begin the process.
That'll give you the AC3 track (or LPCM if that's what it is). Then use BeSweet or HeadAC3he to convert the AC3 to MP3. -
I don't know what I'm doing wrong, but I'm not getting a ACD file. I get a VOB file that I can't extract. I'm rather new at this so I think I'm doing something wrong. Any help?
Is there a free way to do it? Or are you pushing your own software.
Limited funds.
Why can't I get DVD Decripter to convert to ac3? -
dvddecrypter or rejig:
https://www.videohelp.com/forum/viewtopic.php?t=224833#dvddecrypterdemultiplex
and then convert to wav with belight. if that is too difficult buy a software.
You have to highlight the audio stream (make it turn dark blue) as well as check its box, and also then tick Demux. -
Because it's a ripper. That's all it does. It doesn't convert/transcode/encode anything. It just rips. Rips and burns.Originally Posted by keithyd
HTH -
do u know if this can extract audio off the dvd without first ripping the dvd or the audio track itself?Originally Posted by Baldrick
basicly imagine I wanted only 10 seconds of audio off a dvd - can i just get that 10 seconds and nothing else with this program? -
Keith, what Manono said in his last post, you have to check and highlight the stream you want to extract AND choose demux. (otherwise you can right click on any stream, set demux all, and check only the stream(s) you want).
Sorry, I had to go see about a girl
Extract Audio from DVD Files
By foochuck in forum DVD RippingReplies: 7Last Post: 19th Jan 2010, 06:11 -
Extract / isolate 5.1 audio tracks from DVD
By soundchaser in forum MacReplies: 0Last Post: 16th Mar 2009, 13:21 -
Audio is too slow after I extract files from DVD
By DJL82 in forum AudioReplies: 5Last Post: 6th Sep 2008, 19:43 -
question about how to extract mp3 audio from DVD
By jimdagys in forum AudioReplies: 5Last Post: 17th Apr 2008, 11:19 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 19:03
