Hi,
I'm wondering what the best way to record tv in stereo when using an antenna cable to pick up the tv reception. When I connect my vcr to my pc, I plug the audio cable into "Audio In' on my sound card and I get stereo sound that way, but without my vcr, I have to record in mono.
I have the Winfast TV tuner connected to my sound card internally.
WinFast TV2000 XP RM
Hardware Interface 32-bit PCI 2.1 bus mastering
Compatibility Graphics drivers must include DirectX 8.1 software Video Standards
Video Standards NTSC, PAL or SECAM
TV Tuner NTSC, PAL I/DK, PAL BG/DK, PAL M/N, SECAM BG for respective model
Full 181 channels supported
Video Display True color overlay in scaleable video-in-a-window
Video Format RGB32/RGB24/RGB15/YUY2
Drivers WDM drivers for Windows 98SE/ME/2000/XP
Connectors 1 RF TV source reception
1 audio output connector
1 S-video input
1 composite video input
1 phone jack for IR sensor
Bundle software WinFastDVD
Package Contents WinFast TV2000 XP RM card
1 audio cable
WinFast TV drivers/utilities CD-ROM
1 IR Sensor Plug
Remote Controller & batteries
User's manual
Minimum System Requirements One available PCI 2.1 compliant slot
Pentium II 300MHz or higher compatible PC 64MB of system memory
MS Windows 98SE/ME/2000/XP
Graphics sub-system with DirectX 8.1 or above
Remote Controller
16-bit sound card
Results 1 to 1 of 1
2000 DV's Capturing Per Year - Best Approach Help
By ilw in forum Capturing and VCRReplies: 2Last Post: 29th Dec 2010, 13:13 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 12:38 -
Help...Tapes recorded in stereo, capturing from a mono-only player
By sgdavis in forum AudioReplies: 6Last Post: 19th Feb 2010, 16:08 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 14:46 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 21:46
