I have had no real issues with the Beta version but it wont allow me to place a menu on the DVDs before burning, and the system just comes to a stop at the Encoding Menu stage and freezes up at 50.0%
Nothing more happens.....
Any Ideas people?
The progress bar stopping before 100% is a known issue:
https://www.videohelp.com/forum/viewtopic.php?t=267601
Even though the progress bar stops the log will let you know that encoding is finished. Have you checked to see if the DVD folders are there and if the DVD plays?
What exactly do you mean when you say the program will not allow you to place a menu on the DVD? Is there an error message or are you choosing the "Quick DVD" option? The "Quck DVD" has no menu, you must click on the disc icon, not use the drop down selections if you want a menu.
Create Menu's without encoding the video ?
By messi magician in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jan 2012, 18:20 -
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58 -
add menu without re-encoding
By mathmax in forum DVD RippingReplies: 2Last Post: 9th Jul 2010, 11:40 -
How to put a new menu on a DVD without re-encoding...?
By Huntr777 in forum MacReplies: 5Last Post: 13th Sep 2009, 22:18
