  1. I have the DiMAGE Z10 3.2 which lets you capture video without audio. I have captured some video that I recorded onto my SD capture card. The problem is that when I put in my capture card into my LexMark scanner it only asks if I want to copy pictures to my computer, no where I find the video I captured. So 1) I am wondering if the DiMAGE Z10 was even created to convert video to the computer 2) how do I find the video I captured on the SD capture card. thank you for answers, its muchly appreciated!!!
  2. anyone with some help??????
  3. Plug the USB into your Computer,and (transfer) The Video(MPG4?).
  4. Originally Posted by canadateck
    i dont have a usb, well it didnt come with my digi cam, did it???
  5. Cables Included - 1 x video cable 1 x USB cable.
    Use the same Cable that you use to plug in your (Printer).
  6. Originally Posted by canadateck
    ok Im not sure if mine came with a USB cable, ill check though but Im if the DiMAGE Z10 was even created to convert video to the computer becuz from reading reviews of them, it seems it was created for taking pictures? could you help me out on this? thanks!
