Hi
I have a dvd I need to burn , first I need to shrink it
because its over 4.33 gigs .
But I cant shrink it ( or even burn if I could @ this size)
because its missing VTS_01_0.vob.
Some person on usenet suggested I use TMPGEnc DVD Author
But no further instructions did s/he give me .
Could someone please give me some specific guidance on how to perform this task .
It doesnt even have to be with Tmpgenc , any working methods anyone
knows of please advise me .
Thanks mates .
this forum has been great .....
If this is a DVD backup, pop the original back in the drive and just rip the VTS_01_0.VOB file in either DVDDecrypter or Smartripper.
If this is a home video (or smilar) and there's no way to get the original DVD (or it doesn't exist, for whatever reason
), then start up TMPGEnc DVD Author, Create New Project, Add DVD Video, point it to the VIDEO_TS folder, and select the appropriate title from the dropdown box. Configure your own menu(s) if you wish then output and burn.
If in doubt, Google it. -
Thanks for a quick reply
No I dont have original dvd ...So I`ll try other method you suggest
Where you say " select the appropriate title from the dropdown box."
I assume this is step 2/3 ?
I only seen 1 title in this , so there was no drop down box per se
I assume this dvd only had 1 title then .
This method worked fine m8
Thanks alot
PS how does a VTS_01_0.vob come up missing when someone rips a dvd ?
Doesnt make sense , any prog ripping a dvd will produce all files .
Cheers -
Look for the guide on using IFO Edit, that will recreate the missing files for you, dead easy to use
Basically, just load IFO Edit, click on create IFO, and tell it where you're first .VOB file is, then let it do the rest, takes about 2-3 minutes depending on your system and how many VOB files there are
I've done this in the past when ripped movie only and TMPGenc DVD Author starts moaning about missing files -
FWIW http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit covers that procedure.Originally Posted by steptoeIf in doubt, Google it.
.vob and subtitles for second movie on a DVD missing?
By rhinodogz in forum Video ConversionReplies: 0Last Post: 2nd Dec 2010, 16:14 -
One VOB of DVD missing audio, how to correct?
By Olsario in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2009, 13:45 -
FAVC - Missing VIDEO_TS.bup, VTS_01_0, VTS_01_0.BUP, VIDEO_TS (.vob)
By Brent.M in forum Newbie / General discussionsReplies: 14Last Post: 8th Feb 2008, 08:47 -
Missing VIDEO_TS.VOB and all VTS_xx_0.VOB
By PietjePuk314 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 18:44 -
create dvd structure from a .vob
By forare in forum Newbie / General discussionsReplies: 6Last Post: 12th Sep 2007, 04:13
