Everyone usually talks about dvd r media's and currently I'm using tayo yuden dvd-r 4x and 8x and have no problems with them at all. I need a good cd-r media that would cover a wide range of freqencies since i'll be recording sound waves that cover a wide aspect of ranges, is the tayo yuden just as good as their dvd media? I heard of another company that is quite costly but is suppose to make the best cd-r media, any suggestions? or should i stick with tayo yuden? Thanks On a side note beside the recording time the ty 4x and 8x dvd-r media is there a difference in quality? I've used both and do not notice any difference and the 4x is much cheaper, would a higher recording rate be considered better quality in theory? I still burn at 4x with the 8x ty i use.
TY is good CD media as well. With CD media it's far easier to get a good burn with even most cheap CD-Rs compared to DVD media.
About needing to cover a wide range of frequencies, that's really irrelevant to the media you're using. CD is a digital format, if you copy it to disc you copy it to disc. As long as the burn goes fine and the disc is readable, it doesn't make a difference if you're using great media or crap media, the data's just the same either way.
HIGH Quality Video
By videohelpnewbie in forum Video Streaming DownloadingReplies: 4Last Post: 13th May 2011, 12:55 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 07:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
youtube high quality
By Kakiray in forum Newbie / General discussionsReplies: 7Last Post: 1st Jan 2008, 09:48
