Hello...I bought 100 pack DVD-r FujiFilm blank DVD's. It says on the right hand side "up to 8X write speed. When I insert the blank dvd into my drive and start nero...it wont let me write any faster than 1X. Meanwhile a 100 pack of DVD -r 's that I purchased a year ago....the same brand with a 4X write capability, will let me write at 4X speed. I use Nero 6.0 as my program to burn DVD's ...and have really never had this problem. I have tried changing the write speed through nero but when I use the pull down open for speed before the burn process, it only has the 1X option there. Has anyone ever run into this sort of problem. Is there anyway to up the write speed that I am missing?
You don't say what DVD writer you have, but you probably need to upgrade the firmware. If the media you are using is later than the burner, it will not know what the media is capable of being written at and drop back to the safest speed it can burn at. In your case, this is obviously 1x.
I have the Lite-On DVD burner LDW-41ss. Ididnt know I had to check for firmware updates . Thanks I'll try the Lite-On web site .
DVD Rom speed problem
By dafoe in forum DVD & Blu-ray WritersReplies: 8Last Post: 26th May 2010, 11:06 -
Where Have All the Fujifilm DVD-Rs Gone?
By Startropic1 in forum MediaReplies: 3Last Post: 28th Apr 2010, 16:19 -
DVD playback speed problem
By LWC in forum Software PlayingReplies: 3Last Post: 14th Nov 2009, 20:17 -
DVD writing speed problem
By dmckay2007 in forum Authoring (DVD)Replies: 3Last Post: 4th Dec 2007, 16:38 -
problem with write speed of dvd burner`
By mr-scarface in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Sep 2007, 12:58
