Hi,
I set my settings on my monitor on power save mode to close after 20 minutes. After it does that, it would not return to display images after i try to click on keyboard or mouse, i tried different settings and put it to shut down after 1 minute, when it shuts down it does the same thing and would not display images although my comp is still running. Help?
Moving your mouse or pressing keys on the keyboard should be all you need to do. Look on your keyboard for the "resume from standby" or "power" button, and try pressing that. Short of that, just use a screensaver instead of turning the monitor off, or just physically turn the monitor off using the push button when you're away from the computer.
If in doubt, Google it. -
Originally Posted by necboy
Is it Possible to Turn Off Internal HD to Save Power?
By imdaman in forum ComputerReplies: 7Last Post: 18th Sep 2010, 11:27 -
Lots of question from old member coming back!
By overloaded_ide in forum Newbie / General discussionsReplies: 3Last Post: 8th Dec 2009, 21:07 -
My HD YouTube vids not coming out wide-screen
By cameraz in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2009, 16:39 -
Play dvds from dvd drive or from hd to save battery power?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 20:29 -
How to save a Power Point program with audio to different location?
By Captain Satellite in forum ComputerReplies: 8Last Post: 23rd Jun 2007, 23:25
