i've been using nero's standard menu template for a while, and i'm sick of it. how can i add audio to the menu? video? how about an introduction video before the menu? i'll use any programs, but prefferably freeware/shareware. thanks.
Yeah, TSCV will fill all your needs. Tho it has a bit of a learning curve. And it still has some bugs.
Most (note not all) of the bugs have been fixed in the newest verison (d/load at http://www.doom9.org ) and there's a really good guide for using TSCV at:
http://www.personal.psu.edu/users/r/d/rdm186/
The newest verison comes with the CDI files, VCDImager, and CDRDAO bundled so it's MUCH easier to use then the eariler verisons. You'll also need/want TMPGenc to make still/motion menus.
<font size=-1>[ This Message was edited by: Vejita-sama on 2001-12-14 15:48:27 ]</font> -
thanks
<font size=-1>[ This Message was edited by: LiquidHAL on 2001-12-15 13:52:04 ]</font> -
Good as TSCV may be, to get a true understanding of how VCD works (and thus make VCDs at the furtherst possible limits) I suggest that you try using VCDImager and coding your XML by hand: http://www.geocities.com/medinotes/vcd
Regards.
Michael Tam
w: Morsels of Evidence -
It's true that to do everything you should learn how to write your oen XML script files. But if you learn/know XML and use TSCV as a 'script generator' it's still a time saver!
Plus it's nice/easy to make motion/still menus with TSCV. Another choice is Uleads DVD Movie Factory (IIRC ~$50). However you're forced to use Uleads templates and from the reports online you can neither create nor edit the templates.
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 23:48 -
How do you make menus for dvds....
By mmmipa in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2007, 12:33 -
How will I make an AVCD with menus?
By zeldAIS in forum Newbie / General discussionsReplies: 19Last Post: 4th Aug 2007, 15:12 -
very complex
By zoranb in forum MacReplies: 2Last Post: 2nd Jul 2007, 13:36 -
Looking for a presentations program to make dvd menus
By faramith in forum ComputerReplies: 0Last Post: 1st Jul 2007, 10:00
