Can anyone tell me what is wrong? I am trying to burn Windows XP files to the Memorex DVD+R DL discs and getting errors. I have never received any errors with this drive before. Sorry, it is a lot of information but I didn't know exactly what anyone would need....
ERROR:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 12:03:20 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 6:35:34 PM
Nero Version: 6.6.0.13
Internal Version: 6, 6, 0, 13c
Recorder: <_NEC DVD_RW ND-3500AG> Version: 2.98 - HA 0 TA 0 - 6.6.0.13
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: < 16X52X32X52COMBO>Version: 106G - HA 1 TA 0 - 6.6.0.13
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-3500AG atapi Port 0 ID 0 DMA: On
CdRomPeripheral : 16X52X32X52COMBO atapi Port 1 ID 0 DMA: On
DiskPeripheral : Promise Array 1.10 ftsata2 Port 2 ID 0 DMA: Off
OtherPeripheral : Promise RAID Console 1.00 ftsata2 Port 2 ID 4 DMA: Off
DiskPeripheral : ST3160023AS 3.18 viamraid Port 3 ID 0 DMA: Off
DiskPeripheral : ST3160023AS 3.18 viamraid Port 3 ID 2 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3500AG D: CDRom3
16X52X32X52COMBO E: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096604kB)
Free physical memory: 1566MB (1604336kB)
Memory in use : 23 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
13.5.2005
ISO compilation
10:17:18 PM #1 Text 0 File Isodoc.cpp, Line 6194
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:17:18 PM #2 Text 0 File Reader.cpp, Line 127
Reader running
10:17:18 PM #3 ISO9660GEN -11 File geniso.cpp, Line 3293
First writeable address = 0 (0x00000000)
10:17:18 PM #4 Text 0 File Burncd.cpp, Line 3167
Turn on Disc-At-Once, using DVD media
10:17:18 PM #5 Text 0 File DlgWaitCD.cpp, Line 260
Last possible write address on media: 4173823 (927:30.73, 8151MB)
Last address to be written: 4109311 (913:10.61, 8025MB)
10:17:18 PM #6 Text 0 File DlgWaitCD.cpp, Line 272
Write in overburning mode: NO (enabled: CD DVD)
10:17:18 PM #7 Text 0 File DlgWaitCD.cpp, Line 2339
Recorder: _NEC DVD_RW ND-3500AG, Media type: DVD+R9 Double Layer
10:17:18 PM #8 Text 0 File DlgWaitCD.cpp, Line 438
>>> Protocol of DlgWaitCD activities: <<<
10:17:18 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 4109312 (4109312) = #4109312/913:10.62
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 4109312 blocks [_NEC DVD_RW ND-3500AG]
10:17:18 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [_NEC DVD_RW ND-3500AG] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 8415870976, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
4109312 | lead-out | 1 | 0x41 | 0x00
10:17:18 PM #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
10:17:24 PM #12 Text 0 File Burncd.cpp, Line 4051
Cache writing successful.
10:17:24 PM #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
10:17:24 PM #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 2.4x (3,324 KB/s)
10:17:24 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 2609
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:17:24 PM #16 Text 0 File DVDPlusDualLayer.cpp, Line 430
Disc finalized, LBA total Image size: 4109312 (8026MB), Last LBA L0: 2054671 (4013MB)
10:17:25 PM #17 SCSI -1093 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 0, TA 0, LUN 0, buffer 0x038A6400
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0xBF 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x0C 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x02 0x00
10:17:25 PM #18 Text 0 File DVDPlusDualLayer.cpp, Line 519
L0 Data Zone Capacity set to 2054672 (1F5A10h, 4013MB) -> ERROR, capacity different:
L0 Data Zone Capacity on disc: 2054672 (1F5A10h, 4013MB)
L0 Data Zone Capacity requested to be set: 2054672 (1F5A10h, 4013MB)
10:17:25 PM #19 CDR -1093 File ThreadedTransferInterface.cpp, Line 1765
No seek complete
10:17:25 PM #20 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1765
Could not perform start of Disc-at-once
10:17:25 PM #21 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 2.4x (3,324 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 11:05:10 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 4/13/2004 5:39:16 AM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 3:59:44 PM (Adapter driver for rec)
Works now! Grabbed firmware from Liggy & Dee. Used 2TC and now works fine!
Dvd burner error message??
By gl22man in forum DVD & Blu-ray WritersReplies: 4Last Post: 21st Oct 2015, 18:42 -
DVD Flick Error Message
By Dee826 in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 22:08 -
Error message with DVD Santa
By poppy56 in forum Newbie / General discussionsReplies: 8Last Post: 1st Feb 2008, 18:00 -
Weird error message with DVD Shrink
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 31st Jan 2008, 19:12 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
