I have had a Sony DVD RW DW-D22A for about a month now and I use it to backup my DVDs and make copies for myself. However, as of thursday, whenever I try to burn a DVD to DVDR using CloneDVD, it stats burning, and halfway or a little more through the process, it stops and said there was an error, probably due to a media problem. I use Memorex DVD+R and it just stopped working, i tried some other kind of DVD+R that i found in my house, Dynex i think, and the same thing happened.
What do you think is wrong? Is it something to do with the DVD writer or is it bad media or something else? Any help would be appreciated. Could it also be the file that i'm burning? I keep trying to copy the same Movie file. If the file didn't copy properly could that be a factor as well?
Thanks!
Closed Thread
Results 1 to 1 of 1
I need some serious help with Sony DVD Architect burning
By Selavast in forum Authoring (DVD)Replies: 6Last Post: 22nd Feb 2011, 18:57 -
Burning DVD issue with Sony HDR CX 100 (PMB software)
By jungleeravana in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th May 2010, 00:43 -
Sony Vegas Platinum Burning to DVD
By jwillis123 in forum Newbie / General discussionsReplies: 0Last Post: 4th Feb 2010, 08:32 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40
