I was tring to transfer some video from a VCR (in the MPEG 1 VCD format)to my Win98 computer using my ATI AIW card with TV 7.6
I had no problem with the video.
But the audio starts out with some static and then turns to all hiss/static anywhere from 2 to 10 seconds after I play back the capture (no matter what player I use)
What can cause this?
What is the cure?
I have inclosed (in MPEG-1 format) a 10 second sample
Wiring.
Which ATI AIW card?
It may be time you upgrade MMC.Want my help? Ask here! (not via PM!)
[/quote]Which ATI AIW card?
AIW 128 Pro
Wiring
I did, I am using MMC 7.6!
I did try to go higher, but, anything above 7.6 seems not to be very well liked by my computer.
333 MhZ Celeron
320 MB memory
Windows 98
But still, working for 10 seconds then static?
BTW if I use a Microphone/ Mike-in instead of a RCA plug cable from the line out of the VCR to the Line In of the sound card.I get no static! -
I found the answer by going back to MMC 7.1
So, I now can capture again
Thanks for the help
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
My TV Caps have Low Audio Volume and Hiss - ATI AIW 2006 PCIE
By somebodeez in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2008, 08:08 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 16:17
