hey all,
not sure if this post goes here or programming but here goes:
have a quick question, I am making a anime dvd that contains 6 episodes each episode has 4 chapters per episode. Is there anyway to write a script or code set of sequences so that when I hit the skip button twice in seccession. on the remote it does not just skip to next chapter but to the next episode?
thanks,
schunn99
p.s I am using dvd lab pro.
using the newcomer DVD Composer, or even pgcedit, you might be able to make the ANGLE button on the remote control jump to the next Title.
EDIT (to add a method using the menu button in DLP)
In DLP, you can setup the MENU button on your remote control to jump to a Video title. In the connection window, add a Command object in the VTS Domain (add one for each title you want to skip to). Then for the title tracks, use the MENU button on remote to jump to a command object. The end-link for the command object should go to the title you want to play. Now when you hit the MENU button on the remote, it should go to the specific title you specified for the Command Object. Of course, this will take away your ability to jump to a menu using the menu button, but you can still jump to a TITLE menu using the "Top Menu" button on your remote...George
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 22:32 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 21:28 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 23:26 -
dvd lab question
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 23:44 -
DVD Lab question
By rizay in forum ComputerReplies: 7Last Post: 7th Dec 2007, 20:13
