    May 2005
    scotland
    frustrated female please help i am attempting to encode avi files so i can burn them to dvd, in the past i have used nero 6 with no problems but now i have tried nero6, roxio7, ulead movie factory 2 and vso divxtodvd and they all have the same problem about half way through the encoding my pc freezes no error messages come up it just stops and i have to restart if i am burning straight to disc there is no problem it is just if i have to convert first i have no problem with audio files
  2. Member craiggus365's Avatar
    Feb 2003
    too close to Newark, N.J.
    Try to DivFix the file first. If you rebuild the index 1st I find it cures many of the conversion problem. The files' index being damaged will sometimes allow it to play on your computer but hang up during processing. I use this free prog on all of my .AVI files to prevent problems. you can find this tool in the tools section. Good Luck
    "Quit Playing With The Clock..."
    Rudy - Funhouse pinball game
    May 2005
    scotland
    thanx for replying but it is not just the one avi movie that it is happening with i did try divxfix but no difference i have also checked the pc temp to make sure its not overheating and it seems fine. this has really got me stumped
