Not sure if this is the right place to put this question, but i have some cd labels that aren't very adhesive and the labels are peeling up which obviously isnt a good thing. Is there any other sort of adhesive i can apply to the disc that will be safe to use? Im worried about what will happen when the disc gets hot and so i'd need an adhesive that would be ok.
Is there anything out there i can use or do i need some new labels?
The safest thing to do would be to remove those labels and then add new one. Any other substance that is added to the disc could cause it to become unbalanced....and while it doesn't matter so much for CD...it is a big deal for DVD.
Paper labels come off easily with WD40. Just soak the label, let it sit for 15 minutes or so, then it will peel right off. Then clean the disc with alcohol.Google is your Friend -
Better yet is just to remove the labels and dont use them anymore,they just cause too many problems,another better thing to do is buy a printer that prints right to a dvd.
Does BD-R + Label Sticker work?
By rallymax in forum MediaReplies: 4Last Post: 7th Jan 2011, 15:38 -
Epson print CD/Mac - photo editing for DVD label question??
By dvdguy24 in forum MediaReplies: 16Last Post: 20th Aug 2010, 05:51 -
CD/DVD - Label Printing - Picture Size Question...
By shotokan101 in forum Newbie / General discussionsReplies: 8Last Post: 9th Jul 2008, 19:18 -
label making
By yuhr in forum MediaReplies: 4Last Post: 29th Nov 2007, 23:34 -
how to copy a label?
By yuhr in forum Authoring (DVD)Replies: 7Last Post: 20th Nov 2007, 11:46
