Hi, using Virtualdub with mpeg2 import to compress my mpeg2 files to divx/xvid.
Problem comes when I'm compressing the audio to mp3 at about 192 bitrate.
I downloaded and installed Radium Mp3 codec. And when i went to the compression options, it still only lets me compress up to 56 bitrate.
I then uninstalled Radium and downloaded and installed LAME from doom9, and the same thing happens. I can only encode/compress the audio only up to 56 kbits. Help?
Forgive the Noob
did you install the lame mp3 acm? and you should select lame mp3 in virtualdub.
Which Mpeg2 compression codec?
By yugurya in forum EditingReplies: 6Last Post: 20th Jan 2012, 01:35 -
No Huffyuv Codec under VirtualDub Compression
By Ryutso in forum Capturing and VCRReplies: 7Last Post: 28th Jan 2011, 03:31 -
Best MPEG4 compression codec?
By W_Eagle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Jan 2008, 07:12 -
codec video compression?
By coperta in forum MacReplies: 12Last Post: 9th Jan 2008, 11:28 -
Highest Compression Codec?
By Solonor in forum Newbie / General discussionsReplies: 7Last Post: 27th Dec 2007, 18:40
