  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello,
    i was wanting to defrag my hd, however, the analysis, had some files, which i use regularly, in the report as, to be i guess deleted...is there an option somewhere which lets me decide what files should be included, u know wat i mean...thanks
    Wow! You got shocks, pegs... LUCKY!
  2. Member scottb721's Avatar
    Oct 2002
    Australia
    The list of files is just showing which files are fragmented on the HD. These are the files that will be put back together during the derag process.
  3. Yup, nothing gets deleted during a defrag, just moved around.
  4. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok so its safe then...
