  1. Forgive me, i know nearly nothing on this issue. I recently started recording onto DVD's so I have many questions..
    I've heard very good things about Ty Media..
    But from what I've read it only seems to work on computer dvd burners.
    I have Toshiba DVD Recorder purchased from Best Buy..
    I know this may be a stupid question, but will they work fine with that recorder?
    Do These DVD's seem good?
    Authentic Taiyo Yuden DVD-R media, made to the highest standards. Highest quality, suitable for duplication and public distribution. Features archival quality AZO metal dye for today's longest archival playback capabilities. Should last up to 100 years or longer in normal cool dark storage conditions.
    Manufacturer: Taiyo Yuden
    Manufacturer Part#: DVD-R47VAL600SK
    Media Type: DVD-R 4X
    Top Surface: Silver Lacquer
    Recording Speed: 1X - 4X
    Storage Capacity: 4.7 GB / 120 Minutes
    Please give me your opinion
    Thanks!
    Should.
  3. I have burned two hundred of these with a different recorder with no failure to record and just as important, no problems with playback on any standalone or computer player owned. Just ordered another hundred.
  4. I believe your Toshiba recorder specifically recommends Taiyo Yuden in the user manual. I never heard of Taiyo Yuden until I purchased a Toshiba recorder five months ago. Unfortunately, the recorder was defective and I returned it. Since then, I've been using Taiyo Yuden without any problems on a Pioneer recorder and a Panasonic recorder. No, it's not just for computer dvd burners.
