hi,
i had over 40 rmvb movie file (tv-episod) each with 50 mins play time, resolution 640x480, don't know the bitrate.
i need to convert it to dvd format so i can play it on stand alone dvd player.
i prefer to put at least 15 episods on 1 dvd disc (4.7GB), it that possible?
i'm using the program call winavi and tmpeg express right now, but i don't know how to do the setting in the program to fullfill my need.
anyhelp would be great. thanks.
Possible? Yes. Watchable? No. RMVB is much more highly compressed than MPEG2. When you convert to MPEG2 for DVD the files will get much bigger unless you go with really low bitrates which will kill picture quality.Originally Posted by gibkho
You can try KDVD/KVCD templates but they may not work on your player:
http://www.kvcd.net/
HD RMVB Converting Problem
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2010, 16:42 -
Converting .rmvb to DVD Error
By kaozkid in forum Newbie / General discussionsReplies: 5Last Post: 20th Apr 2008, 17:12 -
problem with converting rmvb
By fustyler in forum ffmpegX general discussionReplies: 4Last Post: 29th Aug 2007, 21:11 -
.Rmvb Converting/ Burning DVD problems.
By evan11567 in forum Newbie / General discussionsReplies: 3Last Post: 28th Aug 2007, 01:35 -
Converting .rmvb to avi
By rayrayleeroy15 in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2007, 10:04
