I dont know too much about computers and many people, if this is wrong, will look at me and say what a stupid !#$@. Anyways, I have an internal drive as well as an external on my laptop. I heard that when I'm doing editing if I input from one of these drives and output to the other, this can speed up the process a little b/c it prevents bottlenecking of data going to and from the same source. How true is this?
Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
It's generally true that having two drives will speed up data transfers during editing. But if your external drive is operating much slower than your internal drive, you may not see any improvement.
You can download something like SiSandra to check the speed of your drive's data transfers.
http://www.overclockersclub.com/downloadcenter/download.php?action=file&id=12 -
Also,
- during capture you are only using one drive.
- during editing again, you are playing from a drive and displaying on the monitor. A "render" creates a new element in slow speed on the drive. When it's time to record to an external device. Its a single playback to a stream.
Only so called "realtime" cards need to run multiple realtime streams. In that case, you need a RAID. This isn't what you have.
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 18:27 -
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 11:32 -
Can a pci esata card be both internal and external simultaneously?
By yoda313 in forum ComputerReplies: 9Last Post: 1st Dec 2008, 14:45 -
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 17:33 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 17:12
