Results 31 to 45 of 45
ok so i followed the link (thanks BJ_M), and im at this step:
f. On the right side, under “Value”, type in the New MAC address you want to assign to your NIC. Usually this value is entered without the “-“ between the MAC address numbers.
now here is what the window looks like:
what format do i enter the numbers in, what if the numbers are already taken?
thanks
Wow! You got shocks, pegs... LUCKY! -
try 00012F010BDE
btw -- doesnt mater if already taken
you can see what yours is now by opening a command window and typing "ipconfig /all" (without quotes)
start -> run -> type 'CMD' -> type "ipconfig /all" in the dos liek window"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ok so i get all this system info:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
Windows IP Configuration
Host Name . . . . . . . . . . . .
Primary Dns Suffix . . . . . . .
Node Type . . . . . . . . . . . .
IP Routing Enabled. . . . . . . .
WINS Proxy Enabled. . . . . . . .
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix .
Description . . . . . . . . . . .
Physical Address. . . . . . . . .
Dhcp Enabled. . . . . . . . . . .
Autoconfiguration Enabled . . . .
IP Address. . . . . . . . . . . .
Subnet Mask . . . . . . . . . . .
Default Gateway . . . . . . . . .
DHCP Server . . . . . . . . . . .
DNS Servers . . . . . . . . . . .
Lease Obtained. . . . . . . . .
Lease Expires . . . . . . . . . .
do i just pick an IP and put it in that window that i posted up before (ex. 200.xx.xx) or something? if so how do i know where to put the decimals? thanks
as stated - you can not change your IP except by the means given ... you can change your mac address though, which is not your IP ...
what you want to change it for anyway ?
if you need to - use a proxy and stop hanging out at pr0n sites so much that they ban you
most people WANT a static IP in fact
i dont hang out on those sites... i want to change it because well, i down1o@d, a lot of stuff, and well some one else i know who also does the same said that ROGERS caught him and gave him warning, i guess they traced him through his IP, thats why i want to know to change mine so that im not in any danger... if this post is not allowed tell me so that i can change it...
you must not realize that if you change your IP, rogers changes it and would know your new IP as well as your old one ...
in other words -- you are shit out of luck and should not download .. you have a 60GB a month allowance ... they should not bother you for under that as downloading is (still) legal in Canada - though if it is copyrighted works - you should not do it (and will be soon not legal anyway) ...
they dont have to "trace" him through his IP - they can monitor what you are using in bandwidth what ever your IP is ... since you are going through their system ..
I suspect he went over the 60GB and they warned him about that ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
btw - i understand (but im not positive) that the cap has been raised to 100GB for some people
actually he was way under, about a tenth of the size, when i say dl'ing i mean I-tunes, i dont know wat he was dl'ing, but anyways he was way under, i dl hardly a gig a month. so i dont know why he was warned. (but anyways i wrote "download" in code cuz i thought we werent allowed to type the word in this forum, i didnt want it to be mistaken for w@rez) thanks
so i guess there is really no point to chaging the IP...Wow! You got shocks, pegs... LUCKY! -
if he was warned in that case - it was because he was doing p2p and the riaa pick up on it .... and it was prob. for the uploading anyway ....
there is a forum for rogers users here
http://www.dslreports.com/forum/rogers"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks i appreciate all ur help, ooh and thanks very much for the rogers forum
New Doom9 forum IP address
By Gavino in forum Latest Video NewsReplies: 5Last Post: 2nd Dec 2009, 18:33 -
Cant register after having new pc and i need e-mail address changing too !!
By supernovauk in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 25th Apr 2009, 03:29 -
Changing the address new tool notifications get sent to
By DRP in forum FeedbackReplies: 10Last Post: 21st Jun 2008, 16:33 -
How to trace an IP address ?
By susie in forum ComputerReplies: 11Last Post: 21st Dec 2007, 09:08 -
Changing my IP address?
By Akabane Kurodo in forum ComputerReplies: 24Last Post: 7th Jul 2007, 08:28
