hi guys i couldn’t find my computer in local setting I try it to search but not find either I’m using win xp sp2 I was using before win xp sp1 and everything was alright but know whit sp2 I can't see local sett can same one go any idea.
any help appreciated.
tabit![]()
do you mean "settings" under the start menu?
"local security policy" under admin tools?
IE tools/internet options/security/"local internet"?
Can you be a little more spesific? -
hi stilman
many thanks first of all for you are answer and sorry my english, as i said
my first post is what i'm looking is. if you see win xp sp1 if you go
1- click c:doc and setting.
2- click all user folder then you find LOCAL SETTING after that you see many folders like temp and Temporary Internet Files i know my english is not verry good but i need a help
many thanks for you time guys
tabit
I *think* what you're trying to say is that you can't see your LOCAL SETTINGS folder, and that you could before you upgraded to XP SP 2 ?
If that is the case, it sounds like you may have "Show hidden files and Folders" disabled. To change this, open My Computer, go to Tools > Folder Options and then the View tab, and then change the radio button so that the following is selected:
If in doubt, Google it. -
Yep, what he said
hi jimmalenko and stiltman. many thanks
yes that is what i'm looking for you are verry helpfull persons appreciated for the good help
tabit.
Local Media Streaming
By enutz in forum Video Streaming DownloadingReplies: 2Last Post: 24th Sep 2011, 12:11 -
Microsof Yahoo!... soon on local theaters
By MeDiCo_BrUjO in forum Off topicReplies: 7Last Post: 3rd Feb 2008, 18:15 -
Local digital signal conversion?
By hiramelu in forum DVB / IPTVReplies: 2Last Post: 9th Jan 2008, 04:20 -
can someone please go to their local library and extract subtitles
By jimdagys in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2008, 05:19 -
Streaming messages over local TV's
By Jericho in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2007, 15:13
