I am making an episode disk and am trying to make an intro before the main Menu. I have a 15 second clip I want to play and transition into the episode menu. I Loaded the video and audio into a movie window and made it the First Play, created a transition to the episode menu and linked all of the episodes from there. I compiled the DVD, but when I preview it in WinDVD the opening movie doesn't play. Any suggestions on how to get this to work?
Post your connection window so we can see how it's all hooked up. It sounds OK.
Did you get DVD Lab Pro to create the transition for you ? Or did you have it already ?
If you had it already (I never create transitions and motion in DVD Lab Pro, always outside it), then it should go
First Play -> intro clip (a movie) -> transition clip (another movie) -> menu You shouldn't see any transitions in the connection window.
If you created the transition in DLP, then it will go
First Play -> intro clip -> transition symbol -> menuRead my blog here.
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
DVD Lab Pro Transitions question
By phatk9999 in forum Newbie / General discussionsReplies: 3Last Post: 19th May 2008, 03:06 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 22:26 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 15:41 -
DVD Lab Pro chapters question
By jesterhud in forum Authoring (DVD)Replies: 9Last Post: 23rd Aug 2007, 18:06
