How can I multiplex ac3 and m1v files to MPEG1?
I need a free software that can do that, Because when I wanted to multiplex the files in TMPGEnc (mpeg tools) I got an error.
Results 1 to 23 of 23
Try ImagoMPEGMuxer. If it doesn't work try bbMPEG. It is not bad idea to rename you m1v as mpv.
I downloaded ImagoMPEGMuxer but the this software can only save as MPEG2, but I want to save the ac3 + m1v files as MPEG1.
Actually I wanted to create VCD with AC3. But now I know that I can't do that.
Can I create SVCD with AC3? -
no, vcd and svcd do not support ac3. but it might work in some players anyway.
I don't know if I need to resample the sound to 44100. because 44100 is the standtart of VCD. and 48000 is the standart of AC3.
Sample rate is not the bottle neck. The bottle neck is that very few players support (S)VCD with AC3 at all.
/Mats -
If I will create VCD with sound MPEG-1 Layer II (5.1 suround) it will works on my DVD Player?
Originally Posted by EC
BTW, I've touched on trying to mux AC3 w/ VCD or SVCD before.
My advice, DON'T WASTE YOUR TIME.
also note--Mpeg1Layer2 is 1 or 2 channel only, no 5.1 allowed. What you might be thinking of is Mpeg2Layer2.5 (5.1 and 7.1 allowed also, LF and RF backwards compatible w/ 2 ch)
Scott -
Or you can use Dolby Pro Logic, if your source it's Dolby Pro Logic.
Originally Posted by Hyper Shinchan
If you're saying "You can take your 5.1 channel material, and downmix/matrix it to 2channels (PL) to make it compatible with all (S)VCD players and still have surround", then yes, that's a great idea.
Scott -
http://hypercubemx.free.fr/html/how_to_make_5_1__svcd.html
http://www.uwasa.fi/~f76998/video/svcd/faq/#2
FWIW, SVCD spec does support 5.1 audio track. You lose the multi audio stream option when you use 5.1, however. If you stick with stereo, you can have two distinct audio streams.
Ie. you could have an SVCD with English + Spanish stereo audio, or a single 5.1 audio track (in whatever language you decide upon).
Of course, you could go mono and stick 4 languages on the track too, but you'd have to mux left and right channels together for each audio stream, then select a specific channel during playback, or left and right will overlap if played together./\/\ars /\/\ayhem -
Originally Posted by marsmayhem
/Mats -
The problem is more that the SVCD authoring packages don't really support it, so not many people have had a simple way of using it.
Perhaps it costs more for the package authors to license the 5.1 tech. Not disimilar to MPEG2 licencing fees./\/\ars /\/\ayhem -
Hey, you edited your post
No, SVCD spec doesn't support AC3. It's a competitor to Philips MPEG, and since Philips created the SVCD spec, they didn't see fit to include a competing audio codec./\/\ars /\/\ayhem -
SVCD does not support AC3. It does support multi-channel MPEG. IF, and I repeat IF, you create such a file, have the required multi-channel support on your DVD player AND on your amp, and actually get it to work, you would be the very first person I have seen to report such success.
It's an interesting way to waste several hours, but depending on your source, most likely not worth the hassle.
SFAIK, a prologic type file is the best you can do with SVCD. -
Originally Posted by Nelson37
I believe Philips made a compatible DVD player and amp, but not positive.
Not sure about software to DEcode, finding software to ENcode is tough enough. I vaguely remember finding something that claimed to work, but without the required hardware I didn't pursue it any further.
Now this MIGHT work on a PC, with WinDVD or some such. Never investigated this possibility as I don't have 5.1 speakers on the PC, either. -
If someone wants to futz with this further, perhaps the following link might prove useful:
http://hypercubemx.free.fr/html/mpeg_multichannel_test.html/\/\ars /\/\ayhem
converting m1v to divx
By onlygk in forum Video ConversionReplies: 34Last Post: 28th Oct 2010, 08:24 -
Need something that will multiplex .m2v, .ac3 AND .dat into one .vob?
By Information in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 00:06 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 06:59 -
Used to stream .m1v, but now .m2v and..
By KameronK in forum Video Streaming DownloadingReplies: 3Last Post: 6th Apr 2008, 11:48 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 17:01
